Import OMF to 3D View
Use the 3D View > Import OMF menu option (geogxnet.dll(Geosoft.GX.GEO3DV.ImportOMFTo3DV;Run)*) to create a new 3D View and import selected datasets from an OMF file. The new 3D View is added to the current project and listed in the Project Explorer under the 3D Views section.
This tool can also be accessed from the Project Explorer by selecting 3D Views and right clicking Import OMF to 3D View.
Import OMF to 3DV dialog options
For most of the datatypes that are contained in an OMF file, a new Geosoft file type is created.
For example:
- Points - for each points dataset, a Geosoft database (.gdb) is created, and the points are imported to this database. The points locations are then displayed in the 3D View.
- Lines - for each lines dataset, a vector line object is displayed in the 3D View. No new file is created on disk.
- Drillholes - for each set of drillholes there might be several related datasets, for example, collars, traces, downhole measurements of numeric or text values. For each set of data, a new Geosoft database (.gdb) is created, and the data are imported to this database. The drillhole information is then displayed as points in the 3D View.
- Surfaces - for each 3D mesh dataset, a Geosoft surface file (.geosoft_surface) is created, and the 3D mesh data is imported. The surface is then displayed in the 3D View.
- Grids - for each raster dataset, a Geosoft grid file (.grd) is created, and the raster data is imported. The grid is then displayed in the 3D View.
- Block models - for each block model, a Geosoft voxel file (.geosoft_voxel) is created, and the block model data is imported. The voxel is then displayed in the 3D View.
After creating the 3D View, you may add additional data to the view, using the Add to 3D menu.
What is OMF?
The Open Mining Format (OMF) is an open geoscience exchange format for sharing 3D geospatial data within the mining industry. OMF provides a common file format for mining software, and allows files to be easily imported or exported between programs. It is specifically designed to represent spatial objects, such as drillholes, block models and surfaces.
The Open Mining Format offers:
- The ability to easily share data between software packages
- The capacity for companies to seamlessly share data internally or externally
- A more streamlined and efficient approach that eliminates manual or convoluted transfer processes
About OMF and the Global Mining Guidelines group
The first version of OMF, launched in 2017, supports basic structures including points, lines, surfaces, meshes and volumes. The second version will be extending the support of block models.
The Open Mining Format is a collaborative effort, created under the guidance of the Global Mining Guidelines group (GMG). The GMG is focused on fostering broad industry engagement, which is key for this initiative’s success. The GMG has initiated a global outreach program including a sub-committee comprised of representatives from software vendors and mining companies working together to direct the future of the format.
For more information go to:
Which software vendors and applications can create and/or import OMF files?
Several software vendors have adopted, or are in the process of adopting OMF as a common format for exchanging mining datasets.
These include:
Vendor |
Software |
| Deswik | Deswik.CAD 2019 |
| Dassault Systèmes |
GEOVIA Surpac 2019 MineSched 2019 |
| Micromine | Micromine 2020 |
| Seequent (formerly Geosoft) |
Oasis montaj 9.7+ Target 9.7+ |
| Seequent (formerly Aranz Geo) | Leapfrog Geo 4.2+ |
