New Blank Map Template
Use the Map Tools > Map Template > New Blank Map Template menu option (geogxnet.dll(Geosoft.GX.MapTemplate.MapTemplate;CreateEmpty)*), to add a blank map template to the current project.
New Blank Map Template dialog options
When you are satisfied with your selection, click the OK button. The Save Map Template As dialog will be displayed. It is always recommended to save all you project data in your current project directory. Specify a name and click the Save button.
Templates are usually added to a project with the intent specifically to be used for a project (it is possible to create maps from templates in a project as well as from ones in the library) or to manipulate the layout and contents and then adding the template back to the library with the same or different name.
