Display 3D Line Path
From the Add to 3D menu in the 3D Viewer, select the 3D Line Path option to display the 3D line path of data surveyed along lines.
3D Line Path dialog options
Line Colour |
Select the line colour. Script Parameter: PATH3D.LINE_COLOUR |
Check this box to plot labels. By default, it is checked. Script Parameter: PATH3D.PLOT_LABELS [Checked:1 | unchecked:0] |
Label size |
The label size in ground units. Click on Script Parameter: PATH3D.LABEL_SIZE |
Label colour |
Select the label colour. Script Parameter: PATH3D.LABEL_COLOUR |
Label position |
Choose one of the positions from the drop-down list. Script Parameter: PATH3D.LABEL_POSITION |
Label offset |
The label offset in the ground units from the end of the line. It is recommended to set it equal to label size. Script Parameter: PATH3D.LABEL_OFFSET |
Gap tolerance |
Maximum distance between 2 adjacent points on the line before breaking the line. By default, each line is plotted as a solid line with no breaks. Script Parameter: PATH3D.GAP |
The 3D line path is plotted as solid lines. No options are offered for customizing the thickness or style of the line.
Plot line labels
to calculate an optimal size. The optimal size is set to 1% of the largest dimension of the voxel.
