Background Task Manager
Use the Manage Background Tasks dialog to check the status of your background tasks and output files and load any of the successfully generated files into your current project. You have the option to add the generated grid(s) to the Project Explorer as well as displaying them in a Grid Viewer in your project workspace.
Task |
The name of the gridding method. |
Type |
The database channel used in the gridding process. |
Time |
The date and time of task completion. |
Status |
The job status is reported (and highlighted) as one of the options below:
Output |
The output file name. |
File status |
The status of the output file is reported as one of the options below:
If the grid name is repeated in the Output column, the File status will update for each entry.
[Load] |
The Load button is enabled for each of the successfully created grids that have not been loaded yet into the project. Press the button to load the file into your current project and add it to Project Explorer. |
[Display grid when loading in Project Explorer] |
Check this box to display the grid in the current project workspace in a Grid viewer. If unchecked, the grids will be added to the current project and listed in Project Explorer, but they will not be opened in the project workspace. |
[Refresh] |
Click on the Refresh button to update the status of your background tasks: the Time, Status, File status, and Load entries will be updated. This can be very useful with a long process that is showing a "Pending" file or a "Running" task status for a while. |
* If the background task is executed from the Grid Data tool, a log file is created every time the GX is run with the option Run in background enabled. The file is dated and time stamped and can be found in the project’s working directory.
Quitting Oasis montaj, closing the project, or saving the project as another name clears the Manage Background Tasks ("MBT") dialog. Returning to an existing project will not repopulate the MBT dialog.
Loading a grid, then closing the MBT dialog and the grid, will provide the option to reload the grid when the dialog is reopened.
Manually displaying a grid that was created with the 'Run in background' option will have the File Status updated to "Displayed" and the Load button cleared if the option 'Display grid when loading in Project Explorer' is enabled.
Moving the output grid file over to a new directory will update the corresponding entry in the MBT dialog: Status will become "Obsolete" and File Status will be "Deleted". If the file is moved back, the Status is set back again to "Success", the File status to "Created", and the file will be ready to "Load".
