ANOX (annotate the X-axis)
Annotate the X axis of a rectangular area on the map.
Command Syntax:
att,height,width,space,slant,font
Command Parameters:
        refp  |
        Defines the rectangular area relative to this reference point. The default refers to point 0, the ground coordinate system.  |
        x1,y1  |
        Location of bottom left-hand corner of area to annotate. The default is the plot window defined in the MDF file by the MDFF command.  |
        x2,y2  |
        Location of upper right hand corner of area to annotate. The default is the plot window defined in the MDF file by the MDFF command.  |
        asep  |
        Separation between annotated points. Annotation will either start at x1 or at the first even multiple of asep (depending on the setting of im). By default, a reasonable value is chosen.  |
        tick  |
        Length of label tick in map units. Set tick to 0 to not plot ticks. The default is 0.4 cm. A positive tick size will place tick inside map border and a negative tick size places tick outside map border.  |
        side  |
        Side of the X axis to annotate  |
        -1 Annotate bottom side only.  |
        0 annotate both top and bottom sides (Default).  |
        1 annotate top side only.  |
        sense  |
        The compass direction of the +X axis of the SRS. Based on this direction, a compass direction suffix is added to the annotated number  |
        0 X axis points East (Default).  |
        1 X axis points North.  |
        2 X axis points West.  |
        3 X axis points South.  |
        -1 Do not add compass direction.  |
        orient  |
        Orientation of the annotations  |
        -1 Annotate with tops of numbers pointing left.  |
        0 Annotate horizontally. (Default)  |
        1 Annotate with tops of numbers pointing right.  |
        pref  |
        A text string prefix to add to the beginning of each annotation. The default is no prefix.  |
        im  |
        Annotation increment of asep  |
        0 Only even multiples of asep are annotated.  |
        1 Annotations start at x1.  |
        postoff  |
        Offset of the annotation posting from the map edge. The default is 0.15 cm.  |
        dec  |
        Number of digits after decimal. Defaults determined from asep.  |
        edge  |
        Location of labels  |
        0 Center all labels on annotation tick.  |
        1 Center labels on ticks, but right or left justify labels at the edges of the data window. This prevents overlap of the X and Y annotations by not extending past the edges of the data.  |
Sub-Command Parameters:
        att  |
        Attribute for drawing annotations. The current attribute is used to draw ticks.  |
        height  |
        Character height in map units. (default 2.5mm)  |
        width  |
        Character width in map units. (default 2.5mm)  |
        space  |
        Character spacing in map units. (default 2.5mm)  |
        slant  |
        Slant of the characters in degrees from vertical. The default is the last slant specified.  |
        font  |
        Text font.  |
Example:
ANOX
This will annotate both the top and bottom edges of the valid data area defined by the MDF file named M1.MDF.
