BARV (draw an annotated vertical scale bar)
This command draws a ticked and annotated vertical scale bar at the edges of the currently defined data window.
Command Syntax:
BARV side,offs,asep,tick,sub_tick,att
label,dec,offs,just,angle,att,ht wd,sp,slant,font
title,tref,dx,dy,just,angle,att,ht,wd,sp,slant,font
Command Parameters:
side
Side of window to draw vertical scale bar
  • -1    Draw bar on left side of window (Default).
  • 1     Draw bar on right side of window.
  • offs
    Offset from window edge in map units. The default is no offset
    asep
    Separation between tick marks in world coordinates. The default is chosen based on window dimensions.
    tick
    Size of major tick marks in map units. The default is 0.15 cm.
    sub_tick
    Sub-ticks are placed at sub_tick divisions between major ticks. If sub-tick is 1 (the default), no sub-ticks are added. A sub_tick value of 2 adds a single sub_tick half-way between each asep major tick.
    att
    Attribute used to draw the scale bar.
    Sub-Command Parameters Line 1:
    This line controls the annotation of the scale bar. If the bar is annotated, only the major ticks are labelled.
    label
    Label annotation of scale bar
    0    Do not annotate the bar.
    1    Annotate the bar (default)
    dec
    Decimal places
    -3, -4, etc.   Exponential with (0, 1, etc.) decimal places (values
                         equal to or less than –3)
    -2                 Full precision (Default).
    -1                 Integer.
    0, 1 etc.       Number of decimal places (values equal to or greater
                         than zero)
    offs
    Annotation offset from the bar. Default: 1.5 times the tick size.
    just
    Text alignment
    -1    left justified (Default for side = 1)
    0     Centered
    1     right justified (default for side = -1)
    angle
    The angle in degrees counter-clockwise from the X-axis at which to annotate the axis
    att
    Annotation attribute.
    height
    Annotation height.
    width
    Annotation width.
    space
    Annotation spacing.
    slant
    Character slant (Default 0)
    font
    Text font.
    Sub-Command Parameters Line 2: (this line can be repeated)
    This line controls the title of the scale bar.
    title
    Scale bar title enclosed in double quotes (" ").
    treff
    Title location
    1     title plotted under the bar
    2     title plotted centered on left or right edge of the bar, depending
            on side. (Default)
    3     title plotted above the bar
    dx
    X location relative to the bar at which to plot the title next. The default X location is based on the treff option.
    dy
    Y location relative to the bottom of the bar at which to next plot the title. The default Y location is based on the treff option.
    just
    Title alignment
    -1    left justified (default for side = 1)
    0     centered
    att
    Attribute for plotting title.
    height
    Title height.
    width
    Title width.
    space
    Title spacing.
    slant
    Title slant (Default 0)
    font
    Text font.
    Example
    PAGE ,1,40,24 /DEFINE A PLOTTING PAGE
    WIND 1,5,15,35,23 /DEFINE A DATA WINDOW
    WDEF 0,50000,1000,55000 /MAP WINDOW TO X,Y BUFFERS
    RECT 12 /DRAW A BOX AROUND WINDOW
    BARV –1 /DRAW A BAR ON THE LEFT EDGE
    BARV 1 /DRAW A BAR ON THE RIGHT EDGE
    1 /DEFAULT ANNOTATE BAR
    "MAG" /ADD TITLE TO RIGHT BAR
    This control file will define a page with a 30 x 8 cm window. World coordinates are mapped to the window and these coordinates are annotated on the left and right edges of the window.
  • This command is part of the MAPPLOT GX.
