CHAX, CHAY (label grid cells horizontally or vertically)
These two commands label grid cells horizontally (CHAX) or vertically (CHAY) using alphanumeric characters 1,2,3,... or A,B,C,....
Command syntax:
        CHAX refp,x1,y1,x2,y2,asep,side,orient,im,toffs,alphanum att,height,width,space,slant,font  |
        CHAY refp,x1,y1,x2,y2,asep,side,orient,im,toffs,alphanum att,height,width,space,slant,font  |
Command Parameters:
        refp  |
        Defines the rectangular area relative to this reference point. The default refers to point 0, the ground coordinate system.  |
        x1,y1  |
        Location of bottom left-hand corner of area to annotate. The default is the plot window defined in the MDF file by the MDFF command.  |
        x2,y2  |
        Location of upper right hand corner of area to annotate. The default is the plot window defined in the MDF file by the MDFF command.  |
        asep  |
        Separation between labeled points. Annotation will either start at x1 or at the first even multiple of asep (depending on the setting of im). By default, a reasonable value is chosen. This separation should be the same as the grid separation.  |
        side  |
        Side of area to annotate (bottom, top or both)  |
        -1 annotate bottom side only.  |
        0 annotate both top and bottom sides (Default).  |
        1 annotate top side only.  |
        orient  |
        Orientation of annotation  |
        -1 Annotate with tops of numbers pointing left.  |
        0 Annotate horizontally. (Default)  |
        1 Annotate with tops of numbers pointing right.  |
        im  |
        Annotation increment of asep  |
        0 Only even multiples of asep are annotated.  |
        1 Annotations start at x1.  |
        toffs  |
        Offset, in map units, from the border defined by y1,y2 at which to place the labels. The default is 0.  |
        alphanum  |
        Label type alpha or numeric  |
        0 Use of 1,2,3,... to label  |
        1 Use of A, B, C,... to label  |
Sub-Command Parameters:
        att  |
        Attribute for drawing annotations. The current attribute is used to draw ticks.  |
        height  |
        Character height in map units. (default 2.5mm)  |
        width  |
        Character width in map units. (default 2.5mm)  |
        space  |
        Character spacing in map units. (default 2.5mm)  |
        slant  |
        Slant of the characters in degrees from vertical. The default is the last slant specified.  |
        font  |
        Text font.  |
