CIRC (Draw a Circle, Arc or Wedge)
Draws a circle, arc or wedge on the map by specifying the center of the circle, radius and enclosing angles. The center of the circle can be joined to the start and stop points on the circle to produce a wedge. The circle will be filled with colour if a fill colour is defined in the attribute used.
Command Syntax:
Command Parameters:
        refp  |
        Reference point (0 - 11) from which to refer the following offsets. The default is reference point 0.  |
        x,y  |
        Location of the center of the circle relative to the reference point. The default is current att location.  |
        radius  |
        Circle radius. (No default — must be specified).  |
        a1,a2  |
        Angles to start and end of arc measured as degrees clockwise from the positive X axis. The default is 0,0, which produces a full circle.  |
        enclose  |
        Option to enclose the edges of the circle to make a pie shape:  |
        0  |
        circle center is not joined to arc (Default).  |
        1  |
        circle center is joined to end points or the arc.  |
        att  |
        Attribute to use.  |
        style  |
        Line style  |
        1  |
        Solid (Default).  |
        2  |
        long dashes.  |
        3  |
        dotted.  |
        4  |
        short dashes.  |
        5  |
        long/short/long dashes.  |
        6  |
        long/dot/long dash.  |
        If the style is negative, then a smooth joining line is used. The default is a solid style, with a straight joining line (+1).  |
        pitch  |
        Patterned line pitch. The default is 1.0 cm.  |
Example
CIRC 0,5000,5000,10
This will draw a circle with a radius of 10 units (ground units defined by the MDF) centred at ground location (5000,5000).
