DPRJ (Project Z data into X,Y buffers)
This command replaces the X and Y data buffers with projected coordinates depending on the option selected.
Command Syntax:
Command Parameters:
        popt  |
        1  |
        Replace the X buffer with cumulative distance from the start of the X,Y buffer based on the X,Y coordinates.  |
Other options will be available in the future.
Example
DOPN mag,2 /open MAG.XYZ to read second Z
DXYZ L100 /read Line 100 into buffers
DPRJ 1 /Placed distance in X
DMOV Z,Y /move Z into Y buffer
WIND 1,2,15,22,23 /define a data window
WDEF ,,,,,,1 /define default window coord.
LINA 0 /plot buffer in window
This control file will draw a scaled profile of the data in the second column of Line 100 in data file MAG.XYZ.
