DSCL (Shift and/or scale data in the buffer)
The DSCL command allows you to remove a base and apply a multiplying factor to either the X,Y or Z data buffers.
Command Syntax:
Command Parametes:
xyz |
Either 'x', 'y', or 'z', to indicate which data to modify. |
base |
Base level removed from data (before applying mult). |
mult |
Multiplying factor applied to data after base removal. The formula is as follows: new = (old - base) * mult |
Example
WIND 1,2,15,22,23 /define a data window
WDEF 0,1500,2000 /define window coordinates
DOPN mag,2 /open MAG.XYZ to read second Z
DXYZ L100 /read Line 100 into buffers
DSCL z,48000 /remove 48000 from z data
DMOV Z,Y /move Z into Y buffer
LINA 0 /plot buffer as world coordinate
This control file will draw a scaled profile of the data in the second column of Line 100 in data file MAG.XYZ. A base of 48000 is removed from the Z data before plotting.
Note: This command is part of the MAPPLOT GX.
