DXYZ (Read data from an open XYZ file to data buffer)
The DXYZ command will read XYZ data from an open XYZ file into the MAPPLOT data buffers.
Command Syntax:
DXYZ line,continue,project
Command Parameters:
Example
MDFF m1
PROJ UTM17
DOPN mag,2,,,ll.prj
DXYZ l100
This opens file MAG.XYZ and selects the second Z column to be read into the Z buffer. The data projection is defined by projection file LL.PRJ. The map projection was defined by projection file UTM17.PRJ. The DXYZ command reads line 100 from the data file. The data will automatically be projected from LL.PRJ to UTM17.PRJ.
