LINA (Absolute line draw with symbols)
The LINA command can be used to provide the second and subsequent points on the line. The X,Y points are placed in the data buffer. If no X,Y points are specified, LINA uses the X,Y points in the current data buffer.
Command Syntax:
x,y
Command Parameters:
Sub-Command Lines:
x,y |
Sub-command lines are used to provide subsequent points on the line. Each sub-command line may contain one x,y pair that defines the next point. All points are placed in the current data buffer. |
Example:
LINA 0,2500,2500,2,3,8,4,2.5,3
This command will draw a square box at x=2500, y=2500. The data buffer now contains the coordinates that define the box.
