NAR2 (Draw north and declination arrows)
The NAR2 command plots a north arrow on the map.
Command Syntax:
att,height,width,space,slant,font
Command Parameters:
        refp  |
        Reference point from which to refer the following offsets. The default is reference point 1.  |
        xoff,yoff  |
        Offsets in map units from the reference point at which to place the north arrow symbol. The default is the current att position.  |
        direc  |
        North direction in degrees clockwise from map Y direction. The default is 0 degrees.  |
        length  |
        Length of the north arrow. The default is 60 cm.  |
        att  |
        Attribute to use. The default is att 1.  |
        incl  |
        Inclination of the geomagnetic field vector in decimal degrees. The label "Inclination" can be changed to a different language by setting the desired translation in the Mapplot_Translations.csv file in your %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv directory.  |
        decl  |
        Declination of the geomagnetic field vector in decimal degrees. The label "Declination" can be changed to a different language by setting the desired translation in the Mapplot_Translations.csv file in your %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv directory.  |
Sub-Command Parameters:
This line can be used to set the text characteristics.
        att  |
        Attribute for text. (default 1)  |
        height  |
        Character height. (default 7% length)  |
        width  |
        Character width. (default 6% length)  |
        space  |
        Character spacing. (default 6% length)  |
        slant  |
        Slant of the characters in degrees from vertical. The default is the last slant specified.  |
        font  |
        Text font (default is current font). Refer to the FONT command for descriptions of the available fonts.  |
Example
NAR2 3,-5,5,0,6,,17.0,12.5
Draws a 6 cm north arrow 5 cm left and 5 cm above the lower right corner of the map. The geomagnetic inclination and declination are annotated.
The labels "Inclination" and "Declination" can be changed to a different language by setting the desired translation in the Mapplot_Translations.csv file in your %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv directory.
