PAGE (Define a plotting page)
The PAGE command defines the limits of the map page relative to the plot origin. All map reference points (1 through 9) are defined (or re-defined) after this command.
Command Syntax:
Command Parameters:
x1,y1 |
The plot coordinates of the lower left corner of the page map area in user units (usually centimetres). The default is 1,1 cm. |
x2,y2 |
The plot coordinates of the upper right corner of the page map area in user units (normally centimetres). The default is 20.5, 26.0cm., which is reasonable for an 8.5 x 11 inch or A4 page. |
dx,dy |
Option: The map area may be defined by the (dx,dy) size in user units. If a size is specified, x2,y2 are ignored. |
Example
WIND 1,2,15,22,23 /define a data window
WDEF 0,48000,1500,50000 /define window coordinates
DOPN mag,2 /open MAG.XYZ to read second z
DXYZ L100 /read Line 100
DSWP Z,Y /move Z into Y buffer
LINA 0 /plot buffer as world coord.
This control file will draw a scaled profile of the data in the second column of Line 100 in data file MAG.XYZ.
