RPLV (Define a match string from an internal value)
This command allows you to define a match string based on the setting of an internal plotting parameter, or by reading user input. The match string may then be used in the following commands.
Command Syntax:
Command Parameters:
        match  |
        The match string to be set. This string may be any unique string, but we recommend that it be framed be dots in order to be compatible with command-line replacement strings.  |
        parm  |
        A four letter parameter mnemonic:  |
        ATTR  |
        Attribute name stripped from an attribute defined by text. This allows you to extract an attribute name from an attribute defined previously  |
        DCNT  |
        0 if not the end of the input data file  |
        1 if at the end of the input data file  |
        DEOF  |
        0 if the whole line was read into the buffer  |
        1 if the last line was truncated  |
        DMNX,DMNY,DMNZ  |
        Minimum X,Y or Z (respectively) value in the buffer  |
        DMXX,DMXY,DMXZ  |
        Maximum X,Y or Z (respectively) value in the buffer  |
        DNPT  |
        Number of points in data buffer (integer)  |
        DSCX,DSCY  |
        DLNM  |
        Data buffer line number (integer)  |
        DLTP  |
        Data buffer line type (Line", "Base Line", "Tie Line", "Test Line", "Trend Line" or "No Data" if the buffer is empty)  |
        PPCS  |
        Projection name  |
        PDAT  |
        PLDT  |
        Projection local datum stransform name  |
        PMTH  |
        Projection method name  |
        PUAB  |
        Projection unit abbreviation  |
        PUNI  |
        Projection unit full name  |
        PELL  |
        WDNX,WDNY,WDXX,WDXY  |
        Data window minimum and maximum (respectively) coordinate values.  |
        WGNX,WGNY,WGMX,WGMY  |
        World minimum and maximum (respectively) coordinate values.  |
        WMNX.WMNY,WMMX,WMMY  |
        Map minimum and maximum (respectively) coordinate values.  |
        fmt  |
        A FORTRAN style format with the following syntax:  |
        "(Fw.d)"  |
        Floating point format, where w is the string width, and d is the number of digits after the decimal.  |
        "(Iw)"  |
        Integer format, where w is the width of the field in which the integer is placed right justified. If w is 0, the number is left justified. The default is "(I0)"  |
        prompt  |
        A text string used by the ATTR and USER parameters.  |
group.parm value from the Advanced Settings file i.e. "MAPPLOT.FEET"
Example
RECT 1 /draw a box around plot area
DATT .a. /define attribute .a.
RPLV .a.,ATTR,,.a. /reduce .a. to its name only
RECT 1,2,2,3,3,.a. /plot box legend using .a.
TEXT 1,3.5,3.3,-1,".a." /box legend label
:kt150,0.3 /text attribute override
