SCAL (Draw a scale bar)
The SCAL command draws a scale bar and/or the map scale.
Command Syntax:
att,height,width,space,slant,font
Command Parameters:
        refp  |
        Reference point to which to refer the following offset.  |
        xoff,yoff  |
        Location relative to the reference point at which to place the scale bar. The scale bar is centered on this position.  |
        scale  |
        The map scale (i.e. 50000 for 150000, 2400 for 1 inch = 200 feet). The default is taken from an MDF file defined by the MDFF command.  |
        unit  |
        The units in which to report the scale  |
        mt:  |
        Metres  |
        km:  |
        Kilometres  |
        ft:  |
        Feet  |
        kf:  |
        Kilofeet  |
        mi:  |
        Miles  |
        The default is determined from the unit factor (UFAC) reported in the MDF file and can be changed to a different language by setting the desired translation in the Mapplot_Translations.csv file in your %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv directory.  |
        length  |
        The maximum length allowed for the bar. The default is 10 cm.  |
        nsec  |
        Number of major divisions in the bar. The bar will divide the left-most division into five sub-divisions. By default this is chosen automatically.  |
        dsize  |
        The length of each major bar division in ground units defined by the unit parameter above. By default this is chosen automatically. Note: If nsec and dsize are specified, length is ignored.  |
        sopt  |
        Scale options  |
        0  |
        Plot the scale only (no bar).  |
        1  |
        Plot the bar only (no scale).  |
        2  |
        Plot the bar and the scale (default).  |
        bwid  |
        The width of the bar. The default is 0.18 cm.  |
Sub-Command Parameters:
        att  |
        Attribute for text.  |
        height  |
        Character height.  |
        width  |
        Character width.  |
        space  |
        Character spacing.  |
        slant  |
        Slant of the characters in degrees from vertical. The default is the last slant specified.  |
        font  |
        Text font (default is current font). Refer to the FONT command for descriptions of the available fonts.  |
Example
SCAL 2,0,10
A scale bar based on the scale defined in M1.MDF is plotted 10 cm above the bottom center of the map.
Notes:
The unit label and the text "Scale" can be changed to a different language by setting the desired translation in the Mapplot_Translations.csv file in your %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv directory.
This command is part of the MAPPLOT GX.
