TXTB (Plot a file of text)
The TXTB command plots text from a file as a text block. The command line gives the text file name and the sub-command line may optionally be used to set new text characteristics.
Command Syntax:
TXTB refp,xoff,yoff,just,dy,file
att,height,width,space,slant,font
Command Parameters:
refp
Reference point (0 - 11) from which to refer the following offsets. (Default is reference point 1.)
xoff,yoff
Point at which to plot text. The default is the current att position.
just
Text justification
-1    left justify at xoff,yoff (Default).
0     Centered at xoff,yoff.
1     right justified at xoff,yoff.
dy
The line spacing. The default is 1.5 times the text height.
file
The name of an ASCII file containing the text.
Sub-Command Parameters:
att
Attribute for text.
height
Character height.
width
Character width.
space
Character spacing.
slant
Slant of the characters in degrees from vertical. The default is the last slant specified.
font
Text font (default is current font). Refer to the FONT command for descriptions of the available fonts.
Example
MDFF m1
TXTB 3,-10,40,-1,NOTES.DAT
Plots the text in file NOTES.DAT along the right margin of the map. The current default text characteristics are used.
  • This command is part of the MAPPLOT GX.
