XYZ Data Buffer
MAPPLOT maintains an internal data buffer that can hold XYZ data. XYZ data is positioned data defined by a location (X,Y) and data value (Z). The data buffer may contain up to 8000 data points (or up to limited memory). These data points may be read from a Geosoft XYZ file, or may be defined by some of the MAPPLOT graphics commands.
The following list summarizes the commands that work with XYZ data:
        DLST  |
        List the contents of the XYZ data buffer.  |
        DMOV  |
        Copy the contents on one buffer into another.  |
        DOPN  |
        Open an XYZ file.  |
        DPST  |
        Post data values from the XYZ data buffer.  |
        DXYZ  |
        Read a line of data from an XYZ file and load it into the XYZ data buffer.  |
        DSCL  |
        DSWP  |
        Swap two buffers.  |
        DWND  |
        Window data in the XYZ buffer.  |
        DPRJ  |
        LINA,LINR,LIND  |
        POLY  |
        Draw a polygon using X,Y coordinates in the XYZ buffer.  |
        RPLV  |
        Set a match string based on the data in the XYZ buffer.  |
        SYMB  |
        Draw symbols using X,Y coordinates from the XYZ buffer.  |
        WDEF  |
        Defines window coordinates optionally based on the data buffer data range.  |
