Calculate Draped Survey Altitude
Use the Calculate Draped Survey Altitude option (geogxnet.dll(Geosoft.GX.AirborneQC.CalculateDrapedSurveyAltitude;Run)*) from the Airborne QC > Generate Flight Path Plan menu to generate the projected draped flight altitude above the terrain, given a rate of climb or descent.
The option is also available with the UAV Merge Sorties extension under the UAV Merge Sorties > Plan Survey menu.
Calculate Draped Survey Altitude dialog options
Input survey database
Provide the database containing the X&Y coordinates of the survey path.
Script Parameter: QC_DRAPED_ALTITUDE.DATABASE
Input topography grid
The digital elevation model in grid format covering the survey database.
Script Parameter: QC_DRAPED_ALTITUDE.TOPO_GRID
Climb gradient (%)
The aircraft climb rate. This value is the safe vertical distance the aircraft can climb over one horizontal distance unit, in %.
Script Parameter: QC_DRAPED_ALTITUDE.MAX_ASCENT_SLOPE
Descent gradient (%)
The aircraft rate of descent rate. This value is the safe vertical distance the aircraft can drop over one horizontal distance unit, in %. If left blank, it defaults to the max ascent rate.
Script Parameter: QC_DRAPED_ALTITUDE. MAX_DESCENT_SLOPE
Air speed (kn)
Provide the survey air speed in knots. The climb/descent rates are then calculated, using the air speed and the climb/descent gradients.
Script Parameter: QC_DRAPED_ALTITUDE. AIR_SPEED
Nominal height
The lowest vertical distance between the aircraft and the terrain.
Script Parameter: QC_DRAPED_ALTITUDE.DRAPE_HEIGHT
Minimum height
After applying the smoothing filter to the drape path, the elevation may drop lower the nominal height in some stretches. The minimum height defines the absolute lowest permissible height.
Script Parameter: QC_DRAPED_ALTITUDE. MIN_DRAPE_HEIGHT
Maximum elevation
Maximum elevation should not exceed this hard boundary. This value is in terms of absolute height and on the same datum as the DEM, rather than terrain clearance.
Script Parameter: QC_DRAPED_ALTITUDE. MAX_ELEVATION
Smooth drape
If checked, a pass of hanning filter is applied to smooth the draped surface.
Script Parameter: QC_DRAPED_ALTITUDE. SMOOTH[1- apply smoothing (default), 0- do not smooth]
Output drape channel
The draped vertical position for each X&Y coordinate in the input survey database is saved in the altitude channel.
Script Parameter: QC_DRAPED_ALTITUDE.ALTITUDE_CHANNEL
Set drape as current Z channel
If checked, the newly created drape channel is tagged as the Z coordinate.
Script Parameter: QC_DRAPED_ALTITUDE.SET_CURRENT_Z [1 -assign as Z coordinate (default), 0 - do not assign Z coordinate]
Disclaimer
This program is not to be used for the creation of the pilot's navigation flight plan for the execution of an airborne survey. The program creates an approximation of a draped flight path only for the purposes of investigating the efficacy of locating potential geophysical targets.
The draped surface is calculated along the survey line, using:
  • the Topography (DEM) as the base reference.
  • the gradient of ascent/descent to control the maximum slope along the flanks of a topography rise.
  • a minimum radius of curvature of 1000m to control the sharpness of the peaks and valleys.
