Display the Survey Plan
Use the Display the Survey Plan option (QCPLAMAP GX)) from the Airborne QC > Generate Flight Path Plan menu to display the survey plan generated by Create a Survey Plan either in the current map or a new map.
Display the Survey Plan dialog options
New map?
Select "Current map" (0) or a "Create new map" (1).
Script Parameter: QCPLAMAP.MAP
Boundary polygon file
Existing boundary polygon file name
Script Parameter: QCPLAMAP.POLY
Boundary colour
Line colour to draw boundary polygon
Script Parameter: QCPLAMAP.BDCOL
Boundary thickness (mm)
Line thickness in mm to draw boundary polygon
Script Parameter: QCPLAMAP.BDTHK
Flight line colour
Line colour to draw survey lines
Script Parameter: QCPLAMAP.SLCOL
Flight line thickness (mm)
Line thickness in mm to draw survey lines
Script Parameter: QCPLAMAP.SLTHK
Tie line colour
Line colour to draw tie lines
Script Parameter: QCPLAMAP.TLCOL
Tie line thickness (mm)
Line thickness in mm to draw tie lines
Script Parameter: QCPLAMAP.TLTHK
Label size (mm)
The label size in mm.
Script Parameters: QCPLAMAP.SIZE
This GX plots the boundary of the survey, the survey lines and the tie lines listed in the current database. The colour and thickness for each category can be set independently. By default, these are plotted on the current map. If the ‘Create a new map’ option is selected, a second dialog box appears requesting the map name. It also enables you to set the map layout and style.
