Sort All by Multiple Channels
Use the Database Tools > Channel Tools > Sort All by Multiple Channels menu option (SORTALLN GX) to sort all channels based on two reference channels. The data is first sorted by a primary reference channel, then for data with the same value in the primary reference channel, the data is sorted by the secondary channel.
Sort All by Multiple Channels dialog options
Primary channel
Primary channel on which to base the sort. The data will first be sorted by this channel, then by the secondary channel.
Script Parameter: SORTALLN.CHANNEL1
Primary sort
Ascending or Descending.
Script Parameter: SORTALLN.ORDER1
Secondary channel
Secondary channel on which to base the sort. For data in which the primary channel is the same, the data will be sorted by the secondary channel.
Script Parameter: SORTALLN.CHANNEL2
Secondary sort
Script Parameter: SORTALLN.ORDER2
Tertiary channel
Script Parameter: SORTALLN.CHANNEL3
Tertiary sort
Script Parameter: SORTALLN.ORDER3
Quaternary channel
Fourth channel on which to base the sort. For data in which the primary channel is the same, the data will be sorted by the secondary channel.
Script Parameter: SORTALLN.CHANNEL4
Quaternary sort
Script Parameter: SORTALLN.ORDER4
Sort read-only channels?
Yes to sort read-only channels, No to not sort read-only channels.
Script Parameter: SORTALLN.READONLY
If a channel is not sampled at the same rate as the reference channels, the reference channels are re-sampled to match the channel being sorted.
All defined channels are used in the sort; e.g. if the third channel is left blank, then the first, second and fourth are used to create the sort index.
If protected channels are not sorted, the fiducial relationships will be lost, and data integrity may be lost.
