Export to KML
Use the Database > Export > KML menu option (geogxnet.dll(Geosoft.GX.UAVSurvey.ExportToKML;Run)*) to export a GDB survey path to a KML file.
The option is also available in the UAV Merge Sorties extension under the UAV Merge Sorties > Plan Survey menu.
Export to KML dialog options
Longitude channel |
Select the Longitude channel. Script Parameter: PLAN_UAV_SURVEY.LONGITUDE_CHANNEL |
Latitude channel |
Select the Latitude channel. Script Parameter: PLAN_UAV_SURVEY.LATITUDE_CHANNEL |
Elevation definition |
You can define the elevation either in units of metres Above sea level (Z is +ive up from sea level) or as Terrain clearance (Z is +ive from the drone down). Script Parameter: PLAN_UAV_SURVEY. ELEVATION_DEFINITION [0 – Above sea level (default), 1 – Terrain clearance] |
Elevation channel |
Select the channel that contains the elevation in the units/ directions specified above. Script Parameter: PLAN_UAV_SURVEY.ELEVATION_CHANNEL |
Output file |
Specify the name of the output KML (.kml) file. Script Parameter: PLAN_UAV_SURVEY.OUTPUT_FILE |
Survey paths generated in the GDB format can be exported to the KML (Keyhole Markup Language) format file.
The KML format is an XML- based format for storing, displaying and sharing geographic data and associated content. KML files can be viewed on Google Earth and are also used by many popular survey software and navigation systems. Most drone navigation autopilot systems can directly interpret KML files.
KML is the most common format for producing UAV navigation files.
