Generate a Clipped Voxel
Use the Voxel > Utilities > Voxel Topography Clip menu option (geogxnet.dll(Geosoft.GX.VoxUtils.VoxClip;Run)*), to produce a new voxel by clipping an existing voxel with topography grid(s).
Generate a Clipped Voxel dialog options
| Input voxel
 | Select the input voxel file. The output voxel will be identical to this one in size, projection and data type. Script Parameter: VOXCLIP.INPUT_VOXEL |
| Output voxel | Specify the name of the voxel file to create. Script Parameter: VOXCLIP.OUTPUT_VOXEL |
| Top grid | Optional Top clipping grid. Script Parameter: VOXCLIP.TOP_GRID |
| Bottom grid | Optional Bottom clipping grid. Script Parameter: VOXCLIP.BOTTOM_GRID |
At least one (top or bottom) clipping grid must be specified. Any grids that do not match the input Voxel will be reprojected.
This GX simply produces a GX for MATHEXPRESSIONBUILDER in the form:
VO = (Z < BottomGrid || Z > TopGrid) ? DUMMY : VM;
