Voxel to GDB
Use the Voxel > Conversions > Voxel to GDB menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ConvertVoxelToGDB;RunVoxel)*), to export a Geosoft Voxel to a database (Geosoft GDB).
Voxel to GDB dialog options
Input voxel
Select the voxel file to be exported to a database.
Script Parameter: EXPDBVOX.VOXEL
Output database
Specify the name of the database to generate. By default, the output database is pre-populated with the same file name as the input file.
Script Parameter: EXPDBVOX.DATABASE
Data channel name
Enter a database channel name to hold the exported voxel data values.
Script Parameter: EXPDBVOX.CHAN
Direction
Specify the direction axis (X, Y, or Z) along which the voxel will be exported.
Script Parameter: EXPDBVOX.DIRECTION [0: XYZ (default), 1: YXZ, 2: XZY, 3: YZX, 4: ZXY, 5: ZYX]
Output dummies
If not checked, dummy voxel elements will be omitted in the output database.
Script Parameter: EXPDBVOX.DUMMY [0-No | 1-Yes (default)]
Direction
The first coordinate in the direction designation indicates the slice plane, the data along the 3rd coordinate changes faster than the 2nd one. For example, in the designation YXZ, an entire slice in the Y plane will be saved as a database line. In each line, consecutive points are ordered along the Z direction, followed by the X direction.
