Filter a Voxel
Use the Voxel > Utilities > Filter a Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.FilterVoxel;Run)*), to apply a filter to an existing voxel and set the output to a new voxel. The filter method can be selected from a predefined list of filters, or can be defined in a filter file.
Filter a Voxel dialog options
Coefficient File Format
The coefficients are given in a left-handed coordinate system in the increasing order of X then Y then Z, where X increases the fastest.
Coefficients are provided in the following format (see illustration)
Line 1: (0,0,0) (1,0,0) (2,0,0) (0,1,0) (1,1,0) (2,1,0) (0,2,0) (1,2,0) (2,2,0)
Line 2: (0,0,1) (1,0,1) (2,0,1) (0,1,1) (1,1,1) (2,1,1) (0,2,1) (1,2,1) (2,2,1)
Line 3: (0,0,2) (1,0,2) (2,0,2) (0,1,2) (1,1,2) (2,1,2) (0,2,2) (1,2,2) (2,2,2)
Variable Cell Sizes
Variable cell size is taken into account for the X, Y, Z and Total gradient filters. All other filters ignore variable spacing.
The filters provided with the installation are explained below:
Filters
Filter |
Coefficients |
Comments |
Smoothing |
0 0 0 0 0.085 0 0 0 0 0 0.085 0 0.085 0.49 0.085 0 0.085 0 0 0 0 0 0.085 0 0 0 0 |
Symmetric filter, sum=1.0 This is basically a 3D Hanning filter. Apply more times to get more smoothing. |
Laplace |
0 0 0 0 -0.16666667 0 0 0 0 0 -0.16666667 0 -0.16666667 1.00000002 -0.16666667 0 -0.16666667 0 0 0 0 0 -0.16666667 0 0 0 0 |
Symmetric filter, sum=0.0 The Laplace is a very simple and useful first-difference filter. It is particularly useful for accentuating and exposing noise, or areas of rapid change. Applying a single Laplace filter followed by two or three smoothing passes is a good way to reveal all the texture contained in a voxel. |
X-gradient |
0 0 0 0 0 0 0 0 0 0 0 0 -0.5 0 0.5 0 0 0 0 0 0 0 0 0 0 0 0 |
The output is adjusted to account for the actual voxel point separations. |
Y-gradient |
0 0 0 0 0 0 0 0 0 0 -0.5 0 0 0 0 0 0.5 0 0 0 0 0 0 0 0 0 0 |
Z-gradient |
0 0 0 0 -0.5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.5 0 0 0 0 |
Total gradient |
The vector sum of the X, Y and Z gradients. |
From file |
The filter file must contain 27 coefficient values. |
Typically, filter coefficients sum to 1 for conservative operations (preserving the sum of values in the original voxel), or to 0 (to apply a difference operation). |
