Export to Scintrex Geophysical Data Format File
Use the IP & Resistivity > Export > Scintrex Geophysical Data Format option (IPEXPSGDF GX) to export lines from the current database to a Scintrex Geophysical Data Format (SGDF) file.
Export to Scintrex Geophysical Data Format File dialog options
SGDF file
Name of the file to create
Script Parameter: IP.SGDFFILE
Export
Select which lines to export. The options are the currently displayed line, the selected lines (the default) and all the lines.
Script Parameter: IP.LINES - "A" : All lines, "S" : Selected lines (default), "D" : Displayed line
IP/Amplitude Channel
For time domain, the channel containing the IP data to export. For frequency domain, the amplitude channel.
Script Parameter: IP.IPCHAN
Phase Channel
For frequency domain, the phase channel. If left blank, the phase is not included in the output. For time domain, this should be left blank.
Script Parameter: IP.IPCHAN2
