Import IP Data from Interpex 12X Format File
                                                    Use the IPIMP1RESIX GX to import data from a single Interpex I2X format file to a specified line.
                                                    Import Interpex I2X format file dialog options
        File to import
        The Interpex I2x format file to import. The file must already exist.
        Script Parameter: IP.I2X_FILE
        Import to Line
        Select the line to import the data to. The line may already exist (in the list), or you may specify a new name. The line name must be a valid Geosoft format line name, such as "L1000".
        Script Parameter: IP.I2X_LINE
        Resistivity (Data) Channel
        Apparent resistivity from image model channel for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_RES_IMAGE_MODEL
        IP (Data) Channel
        Apparent chargeability from image model channel for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_IP_IMAGE_MODEL
        Image Model Resistivity Channel
        Synthetic resistivity data from image model channel for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_RES_IMAGE_SYNTH
        Image Model IP Channel
        Synthetic chargeability from image model channel for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_IP_IMAGE_SYNTH
        Synthetic Resistivity Channel
        Apparent resistivity synthesized from the polygon model channel for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_RES_POLY
        Synthetic IP Channel
        Apparent chargeability synthesized from the polygon model channel for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_IP_POLY
        Resistivity (Polygon) Channel
        IP (Polygon) Channel
        Zonge Resistivity Channel
        Zonge synthetic apparent resistivity for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_RES_ZONGE
        Zonge IP Channel
        Zonge synthetic chargeability for import. Select one from the list, or leave blank and none will be imported.
        Script Parameter: IP.I2X_IP_ZONGE
        Import Mode
        If REPLACE mode is selected, any data previously residing in the specified line (if it already exists) is lost. If the MERGE mode is selected, values in the imported channel will first be set to dummies, then values in the rows with matching Tx1 and "N" positions will be updated with values from the I2X file.
        Script Parameter: IP.I2X_IMPMODE "R" : replace, "M": merge.
                                                    The IPIMP1RESIX GX is used to import a single line of data into the current database from an Interpex I2X format file. Up to 5 data sets may be imported, each with resistivity and IP data: the measured data, the image model values, data synthesised using the image model, and polygon data, calculated using user-created polygon models, and Zonge data.
