Inline IP Pseudo-Section
Use the Inline IP Pseudo-Section menu option (IPPSPLOT GX) to plot one or more pseudo-section maps or grid sections. Map names are constructed from the line number and the channel specified in the control file; e.g. L1000_IP_Avg.map.
Inline IP Pseudo-Section dialog options
IP Plot Control file
Specify the name of the control file for plotting the pseudo-sections. The default file type is ".ipi".
Script Parameter: IP.PLOTFILE
Map Name Tag
If no Map Name Tag is specified, the map names are derived from the database name; e.g. "Database.map". If a tag is specified, it is appended to the map name, for example, if the tag is "_test", the same map would be "Database_test.map".
This feature is useful to avoid overwriting previous maps for different stacked section plots created from the same database.
When grid files are created inside a stacked section plot (for the sections themselves) the grids names are derived from the individual line name followed by the tag name and the extension .grd, fir example, "L100_test.grd".
Script Parameter: IP.MAP_TAG
Plot
Select the lines to plot. The options are the currently Displayed line, the Selected lines (the default) and All lines.
Script Parameter: IP.LINES - "A" : All lines, "S" : Selected lines (default), "D" : Displayed line
[Modify]
Select the Modify button to edit the selected control file, or create a new one, using the "Pseudo-Section Parameters" tabbed dialog tool.
