Create Windowed IP Channel
Use the Create Windowed IP Channel menu option (IPWINDOW GX) to create a new channel of IP values using one or more of the time window or frequency values in an array channel.
Create Windowed IP Channel dialog options
        Array channel:  |
        The name of the array channel to window. Script Parameter: IP.VACHAN  |
        New channel name:  |
        If the channel already exists, existing data is overwritten. Script Parameter: IP.WINCHAN  |
        Windows/ Frequencies to include:  |
        The list of selected channels. The windows to include are to be listed as in the following examples:  |
        0-3,5-6,8,10  |
        : Channels 0,1,2,3,5,6,8 and 10.  |
        0:9  |
        : All windows from 0 to 9  |
        0-9  |
        3-  |
        : Windows 3 and up  |
        -5  |
        : Windows up to and including 5  |
        : (Blank) All windows  |
        Ranges are allowed, indicated with a "-" or ":", and items are delimited with commas or spaces. If this field is left blank, all the windows are used. If there are N windows, then the first window is "0" and the last is "N-1". Script Parameter: IP.IPWINDOWS  |
Regular channel data is required for a number of IP applications, such as plotting pseudo-sections. The IPWINDOW GX creates a new channel from selected array channel columns.
Multiple Windows/Frequencies
For Time Domain array channels, multiple channels are summed using a weighted average based on the width of each time window. For Frequency domain channels, a simple summation of values is used.
