Intersection Information
Use the INTERSCT GX to create an intersection table. Different statistics on intersection deviations can be calculated and saved to an output file.
Intersection Information dialog options
Input X channel
The input X channel.
Script Parameter: INTERSCT.InX
Input Y channel
The input Y channel.
Script Parameter: INTERSCT.InY
Input data channel
The input data channel.
Script Parameter: INTERSCT.InZ
Intersection tolerance
The intersection tolerance. This parameter is ignored if an existing intersection table is used as input.
  • The maximum limit can be set to 10 times the nominal sampling interval.
Script Parameter: INTERSCT.Tol
Tie lines or all lines
Select "All lines" or "Tie lines". This parameter is ignored if an existing intersection table or database is used as input.
Script Parameter: INTERSCT.Lines
Existing intersect table
The existing intersection table or database to get intersections from. If defined, then, instead of re-calculating the intersections from the database, they are read from this (table or database) file. For large databases, the time saved can be substantial.
Script Parameter: INTERSCT.OldTable
Output intersect table
The output intersection table/ database file name.
Script Parameter: INTERSCT.Table
Output statistics file
The output statistics file name. If specified, the statistics (minimum, maximum and standard deviation values) on the survey/tie line intersection deviations are reported in this output file. See Application Notes for more details.
Script Parameter: INTERSCT.StatsFile
The first step in leveling tie lines and regular survey lines is to produce a tie line intersection table or database.
Intersection Table Format (*.tbl)
The output intersection table file tabulates every intersection between tie lines and regular survey lines. It includes the exact ground location of the intersection point, the tie line and survey line numbers, the recorded value on each line, and the horizontal gradient of the data at that location. Following is an example of an intersection table:
/ Intersection Table
/ X Y Tie# TFid TZ TDZ Line# LFid LZ LDZ
8094.09 5336.51 90 1306.97 64180.2 0.068 470 574.133 64197.8 0.463
8106.99 1893.43 90 1409.55 64207.2 0.445 471 2276.95 64266.1 0.211
8049.27 7721.71 90 1030.20 64069.9 0.556 510 599.391 64065.8 0.155
8082.4 6688.47 90 1170.74 64116.5 0.421 490 2304.9 64130.0 0.526
7983.82 0078.85 90 777.000 64078.9 0.558 550 649.575 64069.6 1.376
8058.46 7854.91 90 876.391 64050.9 0.132 530 2282.74 64075.1 0.009
7997.32 2392.99 90 472.451 63904.9 0.759 590 881.501 63852.4 1.427
If the intersection tolerance is greater than 0.0, the points of closest approach within the tolerance will also be recorded, where lines do not actually intersect. The location will be the average of the closest points on each line.
The columns of the table are:
X
X coordinate of the intersection
Y
Y coordinate of the intersection
Tie#
Tie line number
TFid
Tie line fiducial
TZ
Tie line reading
TDZ
Tie line gradient (per fiducial)
Line#
Line number
Lfid
Line fiducial
LZ
Line reading
LDZ
Line gradient (per fiducial)
Intersection Database (*.gdb)
The Geosoft database can be used to store the intersections information. This has several benefits:
1. The exact intersections locations can be plotted to a map using the normal mapping and symbol methods.
2. Quantities such as the mis-tie or gradient values can be easily gridded for display.
3. Intersections are sorted by Tie Line, instead of appearing as a single long list.
To create an intersections database, simply run the Levelling Intersections GX and specify a file of type (*.GDB) as the output intersection table. The XLEVEL GX recognizes both the original *.tbl file format and the new Geosoft Database file as inputs. Each Tie in the intersection table gets its own line in the Geosoft Database file, containing all the line intersections with that tie line.
The channels of the intersection database are:
X
Y
TIE
Tie line number
TIE_FID
Tie line fiducial.
TIE_LEVEL
Tie line reading.
TIE_GRAD
Tie line gradient (per fiducial).
LINE
Line number.
LINE_FID
Line fiducial.
LINE_LEVEL
Line reading.
LINE_GRAD
Intersection_dX
Difference (at each intersection) between the closest X along the survey line and the closest X along the tie line.
Intersection_dY
Difference (at each intersection) between the closest Y along the survey line and the closest Y along the tie line.
Intersection_dDist
Distance (at each intersection) of the intersection deviations, calculated as:
Intersection_dData
Difference (at each intersection) between the closest data reading along the survey line and the closest data reading along the tie line.
CROSS_DIFF
Miss-tie value (LINE_LEVEL - TIE_LEVEL). Note that when the XLEVEL GX is used to extract mis-tie values to the flight database using the "Level Lines" option, the resulting CROSS_DIFF values in the flight database are of the opposite sign, i.e. TIE_LEVEL - LINE_LEVEL.
Intersection Statistics File
The following difference statistics (minimum, maximum and standard deviation values) on the survey/tie line intersection deviations are calculated and reported in the output file:
Min
Max
StdDev
X_Position
Intersection_dX_min Intersection_dX_max Intersection_dX_Dev
Y_Position
Intersection_dY_min Intersection_dY_max Intersection_dY_Dev
Distance
Intersection_dDist_min
Intersection_dDist_max
Intersection_dDist_Dev
Data
Intersection_dData_min
Intersection_dData_max
Intersection_dData_Dev
The XLEVEL GX can be used to extract levelling corrections from the intersection table. The STATLEV GX and the FULLLEV GX can then be used to apply the levelling corrections to the data.
