Tensioned Spline
Use the Tensioned Spline menu option (LVTSPLN GX) to create a smooth (B-splined) level correction channel.
Tensioned Spline (B-Spline) dialog options
Level error channel
Leveling error (difference) channel
Script Parameter: LVTSPLN.ERROR
Output correction channel
Ouput correction channel
Script Parameter: LVTSPLN.OUT
Maximum error
maximum error to consider.
Script Parameter: LVTSPLN.MAX
Smoothness (0.0 to 1.0)
smoothness between 0 and 1.0.
Script Parameter: LVTSPLN.SMOOTH
Tension (0.0 to 1.0)
Tension between 0 and 1.0.
Script Parameter: LVTSPLN.TENSION
Process line types
process "LINE", "TIE" or "SELECTED" lines. Default is "SELECTED" lines
Script Parameter: LVTSPLN.TYPE
This GX will implement a least-squares smooth fitting of scattered, noisy data using cubic B-splines.
The Roughness controls how well the spline will match the observed data within the standard deviation. A small roughness is smoother than a large roughness. A very large roughness will cause the spline to match the data.
The Tension (Tau) controls the horizontal tension applied to the spline surface. No tension results in a minimum of curvature while a tension of 1 results in piece-wise linear interpolation between points.
