Line Attributes
Use the Line Attributes dialog to modify the line attributes of the selected line.
To access the Attributes tool:
Ensure the group to be edited is displayed on the map.
In the Map Manager tree, select the group layer and right-click Edit Vector Group. A shaded frame will appear around the group on the map.
Click inside the frame, and the area to be edited will be highlighted by square symbols. Right-click and select the Attributes option.
To select the entire group, mouse over the selected group and right-click Select All. Right-click again and select Attributes.
Line Attributes Dialog
Draw colour |
To select the colour of the line, click inside the coloured box. The Colour tool will be displayed. |
Thickness (mm) |
Specify the thickness of the line in map units (mm). |
Styled line |
Check the Styled line box, to enable/disable the Styled line parameter. Click inside the enabled Styled line box to display the Line Pattern Attributes dialog. |
