Display 3D Vectors
From the Add to 3D menu in the
, select the 3D Vectors option to display 3D vectors down drillholes. The input database must be open and it must have assigned X,Y,Z channels.
Display 3D Vectors dialog options
X
Y
Z component
The X,Y,Z components of the geophysical field to display, such as the 3 components of the EM field. |
Mask channel
Use the mask channel to exclude the undesirable data from the plot. The masked points are still contributing to the default calculations. |
[More/Less]
Colour method
Select the colour method, "Default", "Histogram equalization", "Normal distribution", "Linear" or "Log-linear". The default is set to Linear. |
Colours
Select the colour scheme for rendering the image of the vectors. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. |
Length of longest Vectors
Specify the length of the longest vector in distance units. The XYZ components are then scaled accordingly. The calculate button sets the maximum vector length to the 90th percentile of the inter-point distance distribution.
Height/base ratio
Specify the ratio of the height of the symbol over the diameter of the base. The larger this value the slimmer the symbols will appear. This is purely esthetic. The default is a ratio of 4. |
Maximum base size
Specify the maximum base distance size. The default is the average sample space. |
Minimum cutoff
Specify the minimum cutoff value. Do not show symbols for a magnitude below the Minimum cutoff . You can use the [Calculate] button at the right of this entry to set it to the mean of the data, minus one standard deviation. |
