Common Keys
The Common Keys section covers the operators and symbols that are used most commonly in math expressions.
        Button |
        Syntax |
        Definition |
        DUMMY  |
        At the cursor the constant DUMMY is added to the Expression. This constant is translated to the appropriate data type by the math engine.  |
        Division  |
        Multiplication  |
        Subtraction  |
        Addition  |
        Open Parentheses  |
        Modulus (Remainder) of a division. For example: 11%3 = 2 (11/3 = 9 with remainder of 2) 12%4 = 0 (12/4 = 3 with remainder of 0)  |
        sqrt(x)  |
        Square Root  |
        Exponent  |
        Closed Parentheses  |
        e  |
        Natural logarithm  |
        The constant 3.14159265358979  |
        Equality  |
        @Var#  |
        Temporary Variable Names. These variables are using at run time and are not saved in the database.  |
Rules for Using Dummy (Placeholder) Values
Dummy (or placeholder) values are treated differently by some operators than by others.
The logical operators (!,>, <, >=, <=, ==, !=, &&, ||) do not check the value to see if it is a dummy and will function as if it were a number or TRUE.
The mathematical operators (+, -, *, /, **, % etc.) will check for dummy values and will ALWAYS return a dummy if any dummies are used in the calculation.
