Copy a Surface
Use the Copy a Surface option (geogxnet.dll(Geosoft.GX.Surface.CopyMeshToSurface;Run)*) to copy a surface from one geosurface file to another geosurface file. This allows you to organize meshes (surfaces) from different sources into the same geosurface file.
Since all surfaces in a geosurface file must have the same coordinate system, the surface to be copied will be reprojected "on the fly" if the coordinate systems of the two geosurface files differ.
You can access the option from the following locations:
The 3D View > Geosurface > Utilities menu
Copy a Surface dialog options
Input geosurface |
Select the "source" geosurface file.
If the input geosurface does not have a valid coordinate system (CS), this field will be flagged. If you choose to proceed, the CS of the source (the input geosurface) will match the CS of the target (the output geosurface) and no reprojection of the surface will occur. Script Parameter: CopyGeosurfaceFile.InputSourceName |
Surface to copy |
Expand the list to select the surface to be copied. These are all the surfaces contained in the input geosurface. The input surface attributes (colour, transparency, clipping settings as well as the mesh render mode) will be retained in the copying process.
Script Parameter: CopyGeosurfaceFile.SelectSurfaceItem |
Output geosurface |
Select an existing "target" geosurface file or specify a new geosurface file. The new geosurface file will inherit the coordinate system (CS) of the input geosurface file (the source). If the output geosurface file (the target) already exists:
If the target does not have a valid coordinate system (CS), this field will be flagged. If you choose to proceed, the CS from the source is assigned to the target (and to all of its other surfaces). Script Parameter CopyGeosurfaceFile.OutputSourceName |
