Import Processed GPS Data
Use the Moving Platform Gravity > Import > Import Processed GPS Data menu option (AGIMPGPS GX) to import a GPS data file into a new database.
Import GPS File into a New Database dialog options
GPS data file |
Name of the GPS data file (ASCII file) to import. Script Parameter AGIMPGPS.FILE |
GPS Date |
GPS date string in format YYYY/MM/DD. Script Parameter AGIMPGPS.DATE |
This GX uses the "ag_impgps.i3" template file from the local directory to import the GPS data file (ASCII file) into a new database, which will be named after the original data file, excluding its file extension.
