Recalculate Gravity from Raw ZLS Data
Use the Moving Platform Gravity > Import > Recalculate Gravity from Raw Data menu option (AGRECALC GX) to recalculate gravity from raw data.
Recalculate Gravity from Raw Data dialog options
Spring tension channel |
The spring tension channel name. The default name is "SprTens". Script Parameter AGRECALC.SPRTENS |
Raw beam channel |
The raw beam channel name. The default name is "RawBeam". Script Parameter AGRECALC.BEAM |
Cross coupling channel |
The cross coupling channel name. The default name is "CrossCoupl". Script Parameter AGRECALC.CRSCPL |
Calibration factor
Calibration factor (Fcal). The default is 0.9966. Script Parameter AGRECALC.FCAL |
K factor of beam (? mv/minute=1mGal) |
K factor of beam (? mv/minute=1mGal) (K) The default is 2 mv/minute=1mGal. Script Parameter AGRECALC.K |
Output recalculated gravity channel |
The output recalculated gravity channel name. The default name is "RecGravity". Script Parameter AGRECALC.OUTCH |
The spring tension channel, SprTens, will be recalculated by dummy the repeat values and linearly interpolating these dummy values, and then stored into the new SprTensRec channel.
The recalculation formula is:
