X location channel
Y location channel
The channels containing the X and Y positions for the arrow vectors.
Script Parameter: ARROWS.X, ARROWS.Y
X vector channel
Y vector channel
The X and Y components of the vectors to plot.
Script Parameter: ARROWS.XV, ARROWS.YV
Scale (units/mm)
The scaling factor to convert from vector magnitude to the length and a size of the plotted arrow. For instance, a scale of 1000 means that a vector of magnitude 2000 will plot as an arrow 2mm long.
If this is left blank, the selected data is scaled automatically so that the largest plotted arrow will measure 10mm.
Script Parameter: ARROWS.SCALE
Arrow position
The position on the arrow to use as the origin; where the X and Y position is to be in relation to the arrow. The choices are at the arrow’s tip, it’s center, or the end of its tail.
Script Parameter: ARROWS.POS (0:Head, 1:Center, 2: Tail)
Head size
The size of the plotted arrow head, in relation to its tail. There are five selections: "No Head" means that only a line is plotted, with the appropriate length and direction. "Small" heads are 1/6 the length of the arrow, "Medium" heads are 1/3 the length of the arrow, and "Large" heads are ½ the length of the arrow. "No Tail" means the that the head is everything; it will be twice the size of the "Large" head. The overall length of the arrow does not change with this setting.
Script Parameter: ARROWS.SIZE (0: No Head, 1:Small, 2:Medium, 3:Large, 4:No Tail)
Head style
Three styles of arrow head are available; The "Lines" style is the simplest, with two lines forming the head. The "Triangle" head is just that, a filled triangle. The "Barb" style is half-way between the line and triangle styles, with the head forming a double "barbed" point, similar to that found on a fish hook.
Script Parameter: ARROWS.STYLE (0: Lines, 1: Barb, 2: Triangle)
Point angle
The point angle controls the angle that the arrow head subtends at the point. The "Sharp" angle is about 35º (or 17º from the shaft). The "Medium" angle is about 65º (or about 32º from the shaft). The "Blunt" angle is 90º (or 45º from the shaft).
Script Parameter: ARROWS.ANGLE (0: Sharp, 1: Medium, 2: Blunt)
Colour
The arrow colour.
Script Parameter: ARROWS.COLOR
Line thickness (mm)
The line thickness for the arrows. If this is left blank, then the thickness scales automatically with the length of each plotted vector, and is set to 1/20 of the length.
Script Parameter: ARROWS.THICKNESS
