Apply Mask to Data
Use the Apply Mask to Data option (CHPOLY GX) to create a mask channel based on a polygon or a rectangle mask file.
The option is available with the following menus:
Database Tools > Geostatistics Toolkit
Geochem Analysis > Classify by Region > in the Geochemistry extension
Apply Mask to Data dialog options
The mask file is an ASCII file that lists all the points in a polygon that defines a region in to include or exclude data. The CHPOLY GX is used to apply the polygonal mask to the database, and creates a mask channel whose values are 1 or dummy, depending on whether the data is masked inside or outside the given area.
