Plot Scatter Graph
Use the Plot Scatter Graph dialog (CHPRSCAT GX) to print a scatter plot.
Plot Scatter Graph dialog options
Title |
Type the title for the Scatter Plot |
Width (mm) |
Width of scatter plot in (mm) |
Symbol size (mm) |
The size of the plotted symbols in mm. |
Plot to |
Select one of "new map" or "current map". |
Locate Plot (plot to current map only)
Bottom left X (mm) |
X Location for bottom corner of the plot. |
Bottom left Y (mm) |
Y Location for bottom corner of the plot. |
[Locate] |
Interactively select the location of the bottom left corner by selecting a point on the current map |
Click on the Print button
in the Scatter Analysis tool. -
Enter a title, the width and symbol size for the plot.
New map names are created in the following format XYplot_XChannel_YChannel.map, or, if a template is specified using the GX parameters, the template name is used. If a map of that name already exists, it is overwritten.
