Save Statistics
Use the Geochem Analysis > Save Statistics option (CHPRSTAT GX) to print Assay channel statistics to a CSV file.
Output Assay Channel Statistics to a File dialog options
The values are printed to a CSV (Comma-separated values) file, suitable for import into a spread-sheet program such as Microsoft ExcelÔ.
The following information is output for each channel:
Number of valid items
Number of items with values greater than 0
Number of non-valid (dummy) items
Minimum Value
Maximum Value
Range of Values (Max-Min)
Mean Value
Standard Deviation from the mean
Variance from the mean
Sum of values
Sum of the squares of values
Geometric Mean
Median Value
Modal Value
Standard Error
Skewness
Kurtosis
