Graduated Colour Symbol Legend
Use the Graduated Colour Symbol Legend (CSLEGEND GX) to place a legend describing the graduated colour symbol scheme on your map. You must input an AGG, ITR, or a ZON file with the colour-value relationship. Run the GX from the Plot Symbol Legend button on the Histogram Analysis tool.
Graduated Colour Symbol Legend dialog options
Title for legend (Optional) |
Title for the legend. Script Parameter: CSLEGEND.TITLE |
Subtitle for legend (Optional) |
Subtitle for the legend. Script Parameter: CSLEGEND.SUBTITLE |
X position (mm) |
Location of the bottom left corner in X Script Parameter: CSLEGEND.X |
Y position (mm) |
Location of the bottom left corner in Y Script Parameter: CSLEGEND.Y |
Colour table |
Select the colour scheme for rendering the graduated colour symbol legend. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: CSLEGEND.FILE |
Symbol |
The symbol type. Script Parameter: CSLEGEND.SYMBOL |
Symbol weight |
The symbol weight. Script Parameter: CSLEGEND.SYMBWT |
Edge colour |
The symbol edge colour. Script Parameter: CSLEGEND.EDGECOL |
The Legend plots the symbols on the left, with the corresponding data ranges on the right. The legend text is scaled using the legend height and the number of colour zones in the graduated colour symbol file; some experimentation may be required with the legend height, width and symbol size to produce a well-balanced output legend.
