Determine UTM Zone - Statistics
After completing the , the Statistics window opens, and a summary report of the calculated UTM zones is displayed. You have the option to save the summary report to a text file.
Statistics dialog options
Database
The current database file name is displayed.
Channel Statistics
Basic statistical information, calculated on the output UTM zone channel, is reported in the following informational parameters:
Channel name
The name of the channel containing the calculated UTM zones.
Line(s)
The lines that have been used in the calculation of the UTM zones are reported in one of the formats below:
Number of items
The total number of entries in the UTM zones channel.
Number of valid items
The number of valid entries in the UTM zones channel.
Number of dummies
The number of empty values in the UTM zones channel.
Zone | Percentage
The UTM zones and the % of data that falls in each integer zone are listed:
Zone
The name of the zone is concatenated using the UTM zone value (which is between 1 and 60) and its corresponding hemisphere designation (N|S).
Percentage
The % of data, rounded to one decimal place.
[Save Stats]
Select this button to save the content of the Statistics window to a text file (see below for an example). The name of the summary report file is concatenated using the database name and the current date.
Summary report file example:
[Statistics Information]
Database: *.gdb Channel name: UTM_Zone Line(s): [All] Number of items: 9 Number of valid items: 8 Number of dummies: 1 Zone | Percentage 30S | 50.0 29S | 37.5 28S | 12.5
