Merge Databases
Use the DBMERGE GX to merge the contents of one or more databases into another. The option is available with the following menus:
  • Database > Import > Geosoft Database Merge
  • Database Tools > Database Utilities > Merge Databases
Missing lines or channels in the target database (i.e., the database to modify) will be created during the merge process.
Merge Databases dialog options
Database to modify
Specify the name of the target database. The current database is selected by default.
Script Parameter: DBMERGE.GDB1
Database(s) to merge
Select one or more databases to merge into the database to modify.
Script Parameter: DBMERGE.GDB2 (separate multiple items with the ‘|’ character.)
Lines/groups to merge
Choose from one of the two available options:
  • "Selected": only the lines selected in the database(s) to merge will be merged.
  • "All": all lines will be merged.
Script Parameter: DBMERGE.LINES
Channels to merge
  • "Displayed": only the channels currently displayed in the database(s) to merge will be merged.
  • "All": all channels will be merged.
Script Parameter: DBMERGE.CHANNELS
Replace existing data?
Decide how data is merged into the database to modify:
  • Select "Yes" to replace any data that exists in the database.
  • Select "No" to only merge data into the channels that contain no data.
  • Select "Append" to append data to the end of existing data.
Script Parameter: DBMERGE.REPLACE
