Digitize Points from a Grid
Oasis montaj provides the ability to interrogate a grid on a point-by-point basis and copy data and position values to an ASCII file. You can use this functionality, for instance, to create new profile lines in a database. You can do this by importing the XYZ file to a new line or exporting the extracted grid profile to a 3rd party application.
Use the Map Tools > CAD Tools > Digitise to XYZ File menu option (DIGIT GX) to digitize points from a grid and place them in an ASCII XYZ file.
Digitise to XYZ File dialog options
        Output file  |
        Specify an output file name. Script Parameter: DIGIT.OUT  |
        Append or Overwrite  |
        Select whether to overwrite (replace all data in the file) or append to (add information to the end of file) any existing information in the output file. Script Parameter: DIGIT.APPEND overwrite file = 0; append to output = 1  |
        Grid name  |
        Specify the grid name. Using the browse button, locate the grid name to interactively digitize and retrieve the X, Y, and Z values.  You can leave this parameter blank, and only the X and Y values will be written to the XYZ file.
        Script Parameter: DIGIT.GRID  |
        Significant digits  |
        Specify the number of significant digits in the output data. Script Parameter: DIGIT.DIGITS  |
        Data prefix  |
        Specify a data prefix. Script Parameter: DIGIT.PREFIX  |
        Delimiter  |
        Specify a delimiter character (default is a space). Script Parameter: DIGIT.DELIM  |
After you click the OK button, your cursor will change to a cross-hair:
- Select a point by clicking the left mouse button. Move the cursor to the next point and click the left mouse button again. The system displays a dashed line between the points.
 - Repeat the step above until all points are selected.
 - Click the right mouse button and select Done from the popup menu.
 - The system creates an *.XYZ file with your digitized points and values.
If no grid is specified, only the X, Y coordinates will be placed in the output file. If a grid is specified, X, Y, and Z values will be placed in the output file.
