Grid Data
Use the Euler 3D > Grid Data menu option (E3MGRGRD GX) to create a gravity or total field magnetic grid (.GRD) file using the minimum curvature gridding method.
Minimum Curvature Gridding dialog options
Minimum Curvature Gridding – Advanced Options
Channel to grid |
(Display only) The select channel to be gridded. |
(Display only) The selected output grid. |
Grid Cell size |
Specify the grid cell size. The grid cell size is in the distance units of the data. We recommend a cell size of ¼ to ½ the nominal data sample interval. The default is one quarter the average data separation based on a statistical average. A smaller cell size may be required if the data is to be contoured (we recommend 2 mm. or 1/10 inch at plot scale for contouring). This can be achieved by specifying a smaller cell size and larger desampling factor (desamp), or by regridding the grid using BIGRID. Script Parameter: E3MGRGRD.CS |
Xmin, Ymin, |
X and Y minimum and maximum coordinates. Leaving this entry blank, produces a grid covering the entire dataset. To grid a subset for the data, enter the limits of the bounding rectangle.To default any of these parameters, you must honour their position along the entry by providing the separating commas. Entering a range of ,0,0,0 will cause the grid to cover the maximum limits of the data plus the blanking distance. If no value is entered for the blanking distance, then the grid will cover the maximum limits of the data plus 8 times the grid cell size. Script Parameter: E3MGRGRD.XY |
Low-pass |
The de-sampling factor is defined as a function of the grid cell size. Before any further calculations, all points within cells of dimension cell_size x desampling_factor are averaged into a single value and placed in the center of the cell. The default desampling (desampling_factor) is set relative to the contributing points as: Desampling has two impacts:
If the database contains less than 100000 contributing points, the default is set to 1, and the only pre-filtering consists of de-aliasing at the cell level. The variogram calculation duration is a function of the square of the contributing points. Increasing this factor visibly cuts down the variogram calculation time while little impact is seen on the variogram curve. Script Parameter: E3MGRGRD.DSF |
Blanking distance |
All grid cells farther than the blanking distance from a valid point will be set to dummies in the output grid. Preferably this parameter should be set to just greater than the maximum distance through which interpolation is desired. Script Parameter: E3MGRGRD.BKD |
Tolerance |
Specify the tolerance required for each grid cell (absolute error, in grid data units). The default is 0.1% of the maximum range of the observed data.For a more accurate grid, decrease the tolerance value. Script Parameter: E3MGRGRD.TOL |
% pass tolerance |
The required percentage of points that must pass the tolerance. The default is 99%. For a more accurate grid, increase the percentage. Script Parameter: E3MGRGRD.PASTOL |
Maximum iterations |
Iterations at the finest coarseness level will stop when the maximum number or iterations is reached. At each greater coarseness, the maximum iterations is reduced by 2. Increase this value if more iterations are required to produce a more accurate grid. Script Parameter: E3MGRGRD.ITRMAX |
Starting coarse grid |
Choose 16, 8, 4, 2 or 1 to indicate the desired coarseness of the starting iteration level relative to the final grid cell size. By starting with a coarser grid, the algorithm is able to produce a reasonable result in under-sampled areas. As the coarseness decreases, the algorithm becomes more sensitive to local features. Only decrease the coarseness from 16 to reduce gridding time. Script Parameter: E3MGRGRD.ICGR |
Starting search |
This is the maximum search radius to use for establishing the starting grid values for the coarse grid. The default is four times the coarse grid size defined by the ‘Starting coarse grid’. If no data is found within the maximum search radius, the mean of the data is used as the starting value. If the search radius is too small, the starting grid can be a poor approximation of the desired grid, resulting in excessive processing time. If too large, too much time will be consumed establishing the original coarse grid. Script Parameter: E3MGRGRD.SRD |
Internal tension |
The degree of internal tension (between 0 and 1). The default is no tension (0), which produces a true minimum curvature grid. Increasing tension can be used to prevent overshooting of valid data in sparse areas; however, curvature in the vicinity of real data will increase. In general, the more sparse areas are present in the data (with localized highs and lows), the higher the tension should be set. Script Parameter: E3MGRGRD.TENS |
Cells to extend |
Edge clipping parameter, the number of grid cells to extend beyond the outside limits of the data. The default (-1) is not to apply edge clipping to the blanking distanced grid. Use this parameter to ensure the grid does not extend too far beyond the actual data limits, which can occur when using a large blanking distance with widely spaced data. Script Parameter: E3MGRGRD.EDGCLP |
