Edit Selected Flight Lines (EDITLINE GX)
Use the EDITLINE GX to edit line information for all selected flight lines. This is useful for changing line types, flight numbers, or dates for a group of lines in a database.
Edit all Selected Flight Lines dialog options
Line type |
Select the line type from the list. If blank, the line type is not changed. Script Parameter: EDITLINE.TYPE |
Date (yyyy/mm/dd) |
Enter the date in YYYY/MM/DD format. If blank, the date is not changed. Script Parameter: EDITLINE.DATE |
Flight number |
Enter the new flight number (integer). If blank, the flight number is not changed. Script Parameter: EDITLINE.FLIGHT |
If any parameters are blank, the parameter is not changed.
The process will stop if the new name of a selected line already exists. All lines processed up to that point will be changed.
"Group" lines are not affected by these operations.
