Show Profiles of Selected Array Elements
In the database window, use the right-click menu option Show Profiles of Selected Array Elements to display only the array elements of interest. This is an interactive tool.
Show Profiles of Selected Array Elements dialog options
Selection
Select the array elements to show in the profile window. Options are:
All times – (Default) all the elements of the array will be displayed.
Early times – the first 10 elements are selected.
Late times - the first 10 elements are selected.
Sample – every nth element is selected.
Select - manually select the times in the table. Holding the Shift key allows you to select a range. Holding the Ctrl key allows you to select multiples times.
The next two items are contextual
Sample interval
If Sample has been selected above, you will be prompted to enter the desampling interval.
Number selected
If you have chosen Early times or Late times, you can specify how many array elements to show.
Total selected
Number of profiles that will be displayed.
Show hidden windows
There are occasions where the array contains heading or trailing dummies. By default, the dummy array elements are omitted from the table in these instances. If you prefer to display them, check this box.
The table in the dialog shows the array elements along with the time windows. Only the profiles of the checked indices will be displayed.
Unassigned time windows are indicated with asterisks.
The profile colours are assigned assuming a linear colour distribution over the entire array channel.
