Create a 3-Grid Composite
Use the Grid and Image > Display on Map > 3-Grid Composite menu option (GRIDIMG3 GX) to place an aggregate of three grid images on a map.
This functionality is similar to the ternary image functionality, except that you have a much wider range of colour and grey tables from which to choose. For example, you could use this functionality to display one grid using a colour table, another using a grey table and another using a green table, and create a specialized composite for interpretation and visualization.
3-Grid Composite dialog options
Colouring method |
Specify the colour zoning method for rendering colour distributions. Select one of the options below:
Script Parameter: GRIDIMG3.ZONE |
Grid name 1 |
Select the first grid name. Script Parameter: GRIDIMG3.GRID1 |
Colour table 1 |
Select the colour scheme for rendering the image of the first grid. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG3.COLOR1 |
Grid name 2 |
Select the second grid name. Script Parameter: GRIDIMG3.GRID2 |
Colour table 2 |
Select the colour scheme for rendering the image of the second grid. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG3.COLOR2 |
Grid name 3 |
Select the third grid name. Script Parameter: GRIDIMG3.GRID3 |
Colour table 3 |
Select the colour scheme for rendering the image of the third grid. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG3.COLOR3 |
Render method |
Select the render method. ADD - All the colours are added together. BLEND – All the colours are added then divided by the number of valid (non-dummy) colours. BLEND EQUAL – All the colours are added then divided by the number of colours. Script Parameter: GRIDIMG3.METHOD |
Click the New Map button to display a grid on a new map. Click the Current Map button to display the grid on the current map. (For a script file, set 'Script Parameter: GRIDIMG3.NEW' to 1 to create a new map or to 0 to use current map).
A recommended configuration is to use the CYAN.TBL, MAGENTA.TBL and YELLOW.TBL table files.
When using ER Mapper ternary colour images, the band numbers should be specified for each colour grid.
As an example, for an ER Mapper file named "Weshade.ers(ERM)", the following should be entered in the three colour bands:
Red-Cyan grid Weshade.ers(ERM;band=0)
Green-Magenta grid Weshade.ers(ERM;band=1)
Blue-Yellow grid Weshade.ers(ERM;band=2)
