Colour-shaded Grid Image
Use the Colour-shaded Grid Image dialog (GRIDIMGS GX) to place a colour-shaded grid image on a map.
Colour-shaded Grid Image dialog options
Grid name |
Select grid name Script Parameter: GRIDIMGS.GRID |
Shading effect |
Select the shading effect option: Normal (RGB) - shading using RGB model If shading using "Wet-look (HSV)", the colour table specified is ignored. Instead, the hsvc.tbl and hsvg.tbl tables are used for the colour and shaded components of the image respectively. |
Colour method |
Specify the colour zoning method for rendering colour distributions. Select one of the options below:
Script Parameter: GRIDIMGS.ZONE |
Colour table |
Select the colour scheme for rendering the colour-shaded grid image. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMGS.COLOR |
Brightness |
The normal brightness is defined at 0. You can change the brightness from -100 (black) to 100 (white) using either the slider bar or by entering an exact value Script Parameter: GRIDIMGS.BRIGHTNESS [range: 0 to 100] |
Contour interval |
The contour interval. Script Parameter: GRIDIMGS.CONTOUR |
Illumination inclination |
Illumination inclination (Default 45 degrees). Script Parameters: GRIDIMGS.INC |
Illumination declination |
Illumination declination (Default 45 degrees). Script Parameters: GRIDIMGS.DEC |
Vertical scale factor. Script Parameters: GRIDIMGS.SCL |
Click the New Map button to display a grid on a new map. Click the Current Map button to display the grid on the current map.(For script file, set Script Parameter: GRIDIMGS.NEW to 1 to create a new map; 0 to use current map)
If a new map is specified, the range of the grid is used to create a basic map layout.
For the "Normal (RGB)" shading effect, the specified colour table and contour interval are used to display the original grid data and the grey.tbl table is used to display the shaded-relief grid.
If the "Wet-look (HSV)" effect is selected, the hsvg.tbl and hsvg.tbl are used to display the colour and shaded-relief grids respectively.
Oasis montaj will create a shaded-relief grid file with the same name as the input grid plus a suffix "_s". For example, if "mag.grd" is the grid name, Oasis montaj will create a shaded relief grid named "mag_s.grd".
You can use the Image Colour Tool to modify the shading parameters if desired.
If you want to see the same data shaded from different directions on different images, use "Grid/Filters/Shaded relief" (gridshad GX) to create separate shaded grids for each of the independent maps. The "2-grid composite" grid display can then be used to display the different shaded grids with the desired original data. Each image will then be controlled independently.
